Poster un nouveau sujet Répondre au sujet  [ 5 messages ]
Mer 17 Mar 2010 13:21
 Une directive FAA pour le changement d'un "software" du B777
Suite à plusieurs incidents survenus au décollage ( dont celui d'Air France à Lagos arret-decollage-d-un-b777-air-france-a-lagos-t14327.html ) , la FAA a sorti une directive exigeant le changement du "software" concernant quelques 800 appareils de type Boeing 777 et ce avant la fin du mois de Juin, cette modif touche le MCP (mode control panel) , directeur de vol , et les 3 pilotes automatiques de cette machine, ceci afin d'éviter des arrêts décollage non désirés:
The US FAA tomorrow will issue a final airworthiness directive calling on operators of more than 800 US-registered Boeing 777s to update the software in the aircraft's three autopilot flight director computers by the end of June to prevent possible rejected takeoffs (RTOs) and poor single-engine climb performance.
The FAA says in January alone there were two rejected takeoffs for Boeing 777s at speeds "above takeoff decision speed following inadvertent engagement of the autopilot on the ground", adding to the seven other reported rejected takeoff cases since 1995.
With the autopilot engaged on the ground, the pilots feel higher than normal control forces when they attempt to pull the control column aft at takeoff speed, a surprise sensation that can lead to a high-speed abort.
"This condition, if not corrected, could result in rejected takeoff at rotation speed, and consequent possible overrun of the runway," says the FAA in the airworthiness directive (AD), to be published 17 March.
Boeing on 22 January issued a service bulletin to operators of all 777 models built before line number 819 giving operators one year to update the autopilot flight director computer (AFDC) software. The airframer says it believes pilots could be mistakenly pressing the autopilot switch on the aircraft's mode control panel (MCP) when attempting on engage the auto-throttle function.
The second possibility is that pilots may mistakenly press the left autopilot switch on the MCP due to their previous training in Boeing 757, 767, 747-400 models, which include a procedure for selecting takeoff thrust by pushing the "N1" or "EPR" or "THR" switch on the MCP.
"Inadvertent engagements of the autopilot while the airplane is on the ground are rare events," Boeing says. "During its 15-year service history, the 777 fleet has accumulated more than 4.8 million flights and there have been just nine reported instances of a rejected takeoff because of inadvertent engagement of the autopilot. There have been no runway overruns or injuries associated with these RTOs."
Training pilots reached by ATI verified that the latter case is likely, as the autopilot switch on the 777 MCP is roughly in the same location as the EPR switch in the other models.
The new software version inhibits the autopilot from being engaged when the aircraft is below 50ft (15m) or if its flaps are extended. During the ground portion, the new software will disengage the autopilot if for some reason it is turned on when the aircraft is on the ground with flaps extended but not in the rollout mode associated with the auto-land function.
The update also maintains the initial engine-out take off pitch target for a longer duration to minimize altitude loss during takeoff, and targets a velocity to maximize climb out performance. Boeing had discovered during simulator runs that an error in the pitch command law of the AFDC had produced "less than optimal" climb gradient for obstacle clearance during one-engine takeoffs.
The FAA disagreed with Boeing's one-year compliance time in the SB however, accelerating the installation schedule due to the "degree of urgency" needed to address the unsafe condition "without compromising safety".
By John Croft.
T'es sûr de ce que tu avances? Va vérifier dans tes docs, les miennes sont depuis longtemps en cave!
Mer 17 Mar 2010 17:12
 Re: Une directive FAA pour le changement d'un "software" du B777
AF va avoir du boulot! :lol:
Et j'ai l'impression que ta réponse est favorable à ceci:
cavalman a écrit:
ouaaa
tu veux mettre la liste de toutes les AD qu sortent ou alors tu es seulement focalisé sur les A330 ?
tu risque d'avoir bcp de taf en cas de reponse positive a la premiere question
Bon OK :arrow:
NB: j'espère que c'est la cas, et que tu vas continué à poster les AD! :P
Un DC-10 qui fait des looping?!
Et un A400M sur le dos?!
DANS QUELLE MONDE ON VIT??!!!!
(bientôt en vacance presque sans internet pour 3 semaines...)
Jeu 18 Mar 2010 08:22
salut,
voila apres cette petite modif il n y aura plus de probleme!
Jeu 18 Mar 2010 16:43
Donc tu vois bien que je ne suis pas focalisé uniquement sur Airbus , Boeing aussi a sa part du gateau :mrgreen:
Ven 19 Mar 2010 21:29
Euh..... c'est pas moi qui a parlé de se focaliser sur 330 comme le laisse entendre ta sitation... :roll:
Mais c'est peut-être une faute l'inattention..... :|
Mais continue a en mettre car c'est très intéressant pour parler technique ensuite :P
